3D Printing Thread - Look What I 3D Printed
cartel
Re: 3D Printing Thread - Look What I 3D Printed
Post by cartel »
cowl drains there is a rad hose that basically fits perfect after cutting it shorter
I'm in for rocker molding ends if anyone ever prints some
Mike Gibson
russaroll
Post by russaroll »
cartel wrote: 22 Jul 2023 22:15 cowl drains there is a rad hose that basically fits perfect after cutting it shorter
part number please.
Post by icehouse »
We got a resin printer at work. For testing I drew up a Datsun Roadster heater control switch knob. Black is the OG one. The orange is version 1 clear is the latest version. I later printed it in black but that's pretty boring.
Legoman27
Post by Legoman27 »
took a lot of trial & error, but I printed a replacement hinge cover for my wagon
71' 510 wagon
03' E46 330xi wagon
99' E39 540i wagon
Post by RONSLYCHUK »
Nice! 3D printers are great things to have.
iceman510
Post by iceman510 »
Is that hinge cover all one piece?
Legoman27
Post by Legoman27 »
iceman510 wrote: 01 Apr 2024 13:21 Is that hinge cover all one piece?
22 separate pieces glued together
71' 510 wagon
03' E46 330xi wagon
99' E39 540i wagon
gooned
Post by gooned »
Perseverance!
Amazing the unobtanium being re-created these days, 👍🏻
Not Now
Post by Not Now »
That is pretty impressive! Nice work.
Post by Rush »
This is a rad thread! I've only worked with FDM but I've made an assortment of bits for my build; carb linkage ball joints, quarter window wedges, shifter bushings, lock knob bezels, door linkage clips, screw inserts for the c pillar vents, grommets, hole plugs, etc.
Post by icehouse »
Rush how did you do the badge? Did you scan it? Find matching font?
I printed this a while ago. For my buddies datsun roadster, RHD parts are impossible to find. So we scanned and printed a LHD one then mirrored and printed it. I love 3D printing. I print stuff all the time. So handy. I printed a thin wall long nut to hold down the remote garbage disposal button in my sink. The threads weren't long enough and they didn't sell the part I needed. It even worked first try! The SLS printer at work prints amazing. Even the threads worked perfectly.
Post by Rush »
That is an impressive piece!
Yeah, I just plopped the one emblem I've got on the flatbed scanner then did the model in Fusion 360.
Post by icehouse »
Rush wrote: 05 May 2024 16:05 That is an impressive piece!
Flatebed scanner is genius! I should have done that with a spacer I made using the OEM gasket!
Post by Rush »
Lol! Yep! Sometimes with all this fancy techy stuff, it's easy to overlook the simple stuff. I just toss a US quarter coin on there with the item then size it in Fusion til the quarter is about an inch (actually, 24.257 mm if you need it to be precise) & that will give you the proper scale for the item. Sorta primitive, but it works!
