resetting twin carb to baseline
510sports
Post by 510sports »
I wish to reset my carb to baseline alongside cleaning it and checking the float and needles etc. The tutorial states that I need to warm the engine to reset to baseline, but my car is running so rich and fouling the sparks that I can barely get it to stay on for more than 10 seconds let alone warm up. Is it okay to reset to baseline even if I can't get it warm at present? I bought the car non-running so don't know how the carb has been tuned or set up which is why I want to do it.
(Sorry if this is a dumb question, I am a newbie mechanic and I want to do as much myself or at least try)
Pjackb
Re: resetting twin carb to baseline
Post by Pjackb »
You can use this guide as a startup point
It's for roadster carbs so theres a few slight differences but the basic principles is the same
http://www.311s.org/su-setup/su-setup.html
510sports
Post by 510sports »
Pjackb wrote: 19 Jun 2023 06:24 You can use this guide as a startup point
appreciate this, i will print it off and use it when adjusting
Post by 510rob »
While you are tuning various things to get yourself towards a less rich baseline, run hotter than normal spark plugs. It will help prevent fouling when you are still pig rich.
