Re: 280ZX vs 300ZX vs 200SX strut options
Posted: 22 May 2014 12:46
240Z caliper:
If your brake rotor is solid, then that's a pretty good match.
With regard to trying to fix the track width, I don't know what your track is currently since your strut/hub combo is pretty unusual. And there were a variety of 200SX struts through the years, unlike the ZX setup that remained the same through the four years of production. But even if you knew which SX strut you had, you might not be able to find the OE hubs/rotors, etc., to change it around. If you can grab the part number off the strut tube, that might help narrow it down.
