the BEST DIY rear cross member?
marks510
Postby marks510 » 03 Sep 2006 14:48
So ive seen slotted, the datsport, the one where you cut the old brackets off and make new ones, etc.
so the question is, whats the best DIY rear cross member for camber and toe adjustment?
duke
RE: the BEST DIY rear cross member?
Postby duke » 03 Sep 2006 15:57
Personally, I like the Datsport style. I allows you to make camber and toe changes by simply turning an adjusting bolt, rather than trying to slide it up and down, and guesing where you end up. I'm planning on making a set up like this for my car.
Postby defdes » 17 Nov 2006 16:19
DukE, did you end up making this? I have a metal shop and want to give it a go. The camber adjustment is visible in a number of shots, how is the toe done? Is it just a bolt screwing in against the crossmember to change the angle of the rear swing arm? Any advice would be great.
duke
Postby duke » 17 Nov 2006 17:33
I haven't made any real progress on this...I do have an extra crossmember, so hopefully so I will be doing something. For toe adjustment my plan was to have a bolt that threads into a hole in the crossmember with a nut on the other side, so you just screw the bolt in to adjust the toe. The other thing that I am planning on doing is to use spherical bearings instead of poly or some other kind of rubber. By doing this I think it will help free up alot of the bind that can happen in the rear suspension when adjusting toe and camber. I'm waiting for access to a milling machine so that I can make the brackets and such, so hopefully I can make some progress soon, but I defineatly want to have it done by next autocross season (march).
Baz
Postby Baz » 19 Nov 2006 02:59
Pics of the V3 toe adjusters are here.
top hat nuts welded in X member.
If you mock up your desired ride camber / toe settings, allow up to 13mm toe.
Choose range and set your sweet spot then distortion of the bushes is minimal.
We are now producing V4 and setting up for an additional full fabed unit to fit short nose diffs.
Postby defdes » 19 Nov 2006 08:27
Baz, no more distributors in the US?
Baz
Postby Baz » 19 Nov 2006 15:09
No we have not. Easier to buy direct.
oop forgot the likk in previous post.
http://datsport.com/Adjustable_rear_cross_member.html
thisismatt
Postby thisismatt » 19 Nov 2006 16:28
Hey Baz, it still seems like the versions pictured would cause binding (or irregular bracket tension) - am I missing something? For example, if you increase positive camber on the right wheel isn't the outer bushing then twisted in a clockwise direction to the crossmember/bracket/bolt?
I'm your huckleberry.
Postby Byron510 » 19 Nov 2006 21:34
I've simply used spherical bushes to solve any of the alignment issues, and you get an extreemly solid conection with no binding or rotational resistance what so ever.
Postby defdes » 19 Nov 2006 21:45
Do you have any pics Byron?
thisismatt
Postby thisismatt » 19 Nov 2006 22:37
Byron: how much did they set you back?
Baz
Re: RE: the BEST DIY rear cross member?
Postby Baz » 20 Nov 2006 15:10
thisismatt wrote:Hey Baz, it still seems like the versions pictured would cause binding (or irregular bracket tension) - am I missing something? For example, if you increase positive camber on the right wheel isn't the outer bushing then twisted in a clockwise direction to the crossmember/bracket/bolt?
Yes it is, but if the brackets are positioned in the sweet spot distortion load
is at a minimum. The right bushes help as well.
Spherical is the way to go, but noisy for street cars & more expensive.
I guess we would have to replace all the bushes with joints including front end if we were to eliminate any bush distortion.
thisismatt
RE: Re: RE: the BEST DIY rear cross member?
Postby thisismatt » 20 Nov 2006 16:59
Right. I guess the "sweet spot" is just a specific camber/toe alignment that you guys found to be most commonly used/desirable?
Baz
Re: RE: Re: RE: the BEST DIY rear cross member?
Postby Baz » 21 Nov 2006 15:30
thisismatt wrote:Right. I guess the "sweet spot" is just a specific camber/toe alignment that you guys found to be most commonly used/desirable?
Thats it. As previously said. If you do your own mock it up first.
Our sweet spot is for high performance street.
Note that the height of the rear diff bracket will also alter alignment over the range.
MikeY
RE: Re: RE: Re: RE: the BEST DIY rear cross member?
Postby MikeY » 21 Nov 2006 16:15
Baz, What to you use to replace the large bushings on the ends of the crossmember. The stock ones are no longer available here in Canada. Can you get them. I belive poly ones are available in the states but I woukld prefer something less harsh.
