N/A FJ20 Build
N/A FJ20 Build
Post by defdes » 26 Sep 2007 10:27
I have been talking about it for years, but now that the race season is drawing to a close, and the race car is in good shape, I can start putting some time into this project. Initally, it will be a carbed FJ, 91mm domed pistons from WISECO with about 10.5:1 c.r.. I have a FI intake, and ultimately will cadge an ECU and wiring from an '84 200SX and run EFI.
Polished crank case...
Polished beams....
Weighing in with the 1930's scale from my grandfather
Post by defdes » 26 Sep 2007 10:28
A couple more of pistons in...
Yellowcar
Post by Yellowcar » 27 Sep 2007 09:36
Looks nice... How much weight did you need to take off the rods?
Post by defdes » 27 Sep 2007 10:22
After polishing, which I imagine took off a few, there was really only about .5-.75 grams needed to balance.
Post by defdes » 28 Sep 2007 11:53
Continuing with short block assembly
Checking cam timing, some adjustments were needed to make alll of the dots line up...
distributor shaft gear
Post by defdes » 29 Sep 2007 07:47
"Say hello to my little friend..."
jason
Post by jason » 29 Sep 2007 07:58
Nice stuff, that's a look I like!
thisismatt
Post by thisismatt » 29 Sep 2007 09:45
What kind of power are you looking at? What octane gas? :)
The FJ sounds like a nice motor...too bad they're so hard to come by. <chant>Turbo, turbo, turbo...</chant>
I'm your huckleberry.
Post by defdes » 29 Sep 2007 10:01
I have heard claims of 185+ with dual mikunis with large nner venturis. It's a 91 octane motor at least.
indy510
Post by indy510 » 29 Sep 2007 10:20
Are you going to race that motor? What class can you race it in? Looks good.
Post by defdes » 29 Sep 2007 10:46
No this is for my street car. I race vintage C sedan.
nickledimeme
Post by nickledimeme » 29 Sep 2007 11:00
I am digging it.....those are some huge juggs.
Post by defdes » 29 Sep 2007 15:29
A couple of details for you who are not familiar:
Big intake side, just smoothed with a die grinder, no porting needed!
Exhaust side of the cross flow...
Upper chain tensioner replaced with a ratchet style from a Mazda. This keeps the chain tension tight at start up a stops the chain rattle these motors are known for due to low oil pressure in the stock tensioner (like L series).
Yellowcar
Post by Yellowcar » 30 Sep 2007 20:24
Cool! I'v never seen the inside of an FJ motor before.
I can see why people like them :D
Post by icehouse » 30 Sep 2007 21:00
Looking good Defdes!! The FJ is my favorite nissan engine!!
