Peter's FJ20ET Datsun 1600 from Australia
Re: 510 from Down Under with FJ20et
when too much traction and power don't mix well
- oops.jpg (198.11 KiB) Viewed 5782 times
Some Boost in my FJ is good....More is better!!!
- PoorMtnKid
Damn not fun! That spectator area is awesome how it's a grassy hill. In las Vegas grass does not grow so when i see it I'm amazed lol
ouch! Is that the stock r160?
No it's an r180 with wolf creek racing axle kit. Hopefully it'sSleepys-14 wrote:ouch! Is that the stock r160?
Just the side flange (stub axle) and seal
- StrutlessWonder
Is your WCR CV kit shorter to use the R180 diff (R180 is 1 inch wider than the R160), or is it the same length as the kit he sells for the R160 diffed 510s? Hopefully the cv joint and axle will be ok, keeping fingers crossed.
What hp and tq numbers is your FJ putting to the wheels?
Your video showed 510s in the 11s and 12s. Impressive stuff.
Kurt Hafer
Im not sure as I ordered it for an r180 in 2007. Hopefully find out
Today what damage was done.
My Fj makes between 400-430 ft lb and 360-390 whp
Yes the light blue 510 ca18 on e85 was quickes twith
11.3 and the black fj20 11.7 and the coupe ran 12.0
- StrutlessWonder
Impressve power!
If you have the cv out, can you measure the axle length and post?
Ideally, the length of just the axle, but if you weren't planning the pull the spacers, maybe just measure outer cv to outer cv to outer cv when joint is fully compressed, or outer alum spacere to outer alum spacer when fully compressed.
Do you safety wire your cv bolts?
Thanks!
Thanks!
Kurt Hafer
All the same, that's some overenginnering on Datsun's part! 4x the torque and drag strip launches (how many?) is what it took to kill a 40-year-old stub!!
Cheers Mate..StrutlessWonder wrote:Impressve power!
Thanks!
Fully compressed outer cv to outer cv is approx 13.5 inches on both sides (for R180) Left side is shorter slightly shorter.
I personally just use loctite thread locker and check them regularly.
To be honest i was amazed that the stub axles have lasted so long with this much torque put through them and over 100 passes
over the years that i have driven the car. They are the fuse in the rear end so to speak.
pics of the Stub axle (what's left of it) and LSD hemisphere end cap
- TorsenEndCapStubAxle.jpg (133.18 KiB) Viewed 5681 times
- brokenStubAxle.jpg (103.39 KiB) Viewed 5681 times
- StrutlessWonder
Thanks for the measurements. IIRC, the spacers are about 1" thick, so they add a total of another 2".
That stub (what is left of it) looks nasty!
You are lucky it didn't take out the moustache bar mount or bodywork, which it might have done had it completely let go. Are you upgrading stubs or just bolting another stock stub in?
Kurt Hafer
Yes I was lucky it was on the start line and not half track at 100mph
For now I'm changing to another second hand R180 and stub axle to
get the car going. When I save up enough, I will upgrade to an
R200 which has bigger stub axles
Re: Peter's FJ20ET Datsun 1600 from Australia
JDM door frame moulds are finally on.
- DoorFrameMoulds_8441.jpg (139.66 KiB) Viewed 5368 times
small update:
new intercooler is now behind the grill.
- TUF510-New-Intercooler.jpg (209.34 KiB) Viewed 5107 times
