Complete set of Refinished Hayashi Super Street Center Lock wheels, hub adaptors, center caps, and locking wrench. Mounted on Toyo Proxies R888 with 66% treadlife. Ran 3 years with no issues. Anti-seize always used on center cap threads. Wheel is rare and no longer in production.
Everything included to put into service on car.
An adaptor bolts onto your wheel hub similar to a spacer and allows you to run these Hayashi Racing centerlock rims. The Center Lock System uses a hub adaptor with conventional PCD. Once the steel adpator is bolted on, slide rim on then thread on the single alloy nut tighten using the centerlock tool (massive socket) with its breaker bar or use a massive torque wrench, tightening to 127 ft. lbs.
Period MotorSport inspired JDM wheel you don’t see at car shows.
Manufactured May1981
Bolt circle 4x114.3
Offset is +2
wheels are14x7
Toyo Proxies are 205/55/14
Can be viewed at link below:
https://www.dropbox.com/sh/jnm7fw189vo8 ... hfi7a?dl=0
$2200 o/bo
local pick up in LA or shipped at buyer’s cost
