Seeking unobtanium - WTB "Option 2" Gearbox for 510 Race Car
- KiKiIchiBan
Re: Seeking unobtanium - WTB "Option 2" Gearbox for 510 Race Car
That's the one made over here.
Do you know who the primary manufacturer is?
wow - the gear ratios here on this listing are pretty close (with the exception of 4th gear)... do you know the name or how to contact the UK company?? thanks!KiKiIchiBan wrote: ↑19 Nov 2021 06:57 There's a UK company that make the gear kit for £3,500.00. You'll pay taxes and shipping and some more taxes on top though.
Option 1 – 1st 2.823, 2nd 1.976, 3rd 1.479, 4th 1.200, 5th 1.00
Option 2 – 1st 2.348, 2nd 1.601, 3rd 1.296, 4th 1.200, 5th 1.00
I know Troy well, actually have one of his dogbox transmissions... it is a fantastic gearbox but I haven't been able to manage the rev matching required on the downshifts and pretty much break the shear pins inside every time I run it (so now it sits strapped to the floor of my trailer). Man though... if you are up for the challenge, it is an amazing gearbox to drive... especially when you can up shift through the gears with a tiny lift off the throttle before choosing the next gear.
Sadly, i am looking for a more traditional shifting experience. That is why i am on the hunt for the USA made Option 2 gearbox so that i can meet the B sedan specifications for vintage races.
- KiKiIchiBan
http://eliteracingtransmissions.com/cat ... -gear-kit/
1st Gear 2.823
2nd Gear 1.976
3rd Gear 1.479
4th Gear 1.200
5th Gear 1.000
1st Gear 2.823
2nd Gear 1.976
3rd Gear 1.479
4th Gear 1.200
5th Gear 1.000
These are Option 3 numbers including the part number.
Option 2 (F5C71B direct drive 5th, dogleg shift pattern) 32010-N3221 are
2.348
1.601
1.296
1.138
1.000
Option 2 (Ultra Close) in FS5C71A, over drive 5th H pattern A type shifter (Roadster 5 speed) are...
1.858
1.388
1.217
1.000
0.852
Thanks for posting that Mike. I was being lazy so here is my penance; I dug out the old Motorsport Schematic catalog and scanned the relevant pages...
- IMG_20211123_0001 (1440p).jpg (547.19 KiB) Viewed 1356 times
- IMG_20211123_0002 (1440p).jpg (208.83 KiB) Viewed 1356 times
- IMG_20211123_0003 (1440p).jpg (346.55 KiB) Viewed 1356 times
- IMG_20211123_0005 (1440p).jpg (167.46 KiB) Viewed 1356 times
- IMG_20211123_0006 (1440p).jpg (158.67 KiB) Viewed 1356 times
I scanned an old Motorsports Parts Catalog too.
- IMG_20211123_0007 (1440p).jpg (352.8 KiB) Viewed 1353 times
- KiKiIchiBan
They make both, also: https://svra.com/wp-content/uploads/201 ... -17.00.pdf510rob wrote: ↑23 Nov 2021 12:55 http://eliteracingtransmissions.com/cat ... -gear-kit/
1st Gear 2.823
2nd Gear 1.976
3rd Gear 1.479
4th Gear 1.200
5th Gear 1.000
This SVRA document lists two products, but the manufacturer's website lists one - who knows...https://svra.com/wp-content/uploads/2017/12/B-Sedan-Challange-17.00.pdf wrote:2.0 TRANSMISSIONS B-SEDAN
Stock case synchromesh transmissions 4 or 5 speeds are acceptable.
Reverse must be fully functioning.
2.1
Dog Ring transmissions in a stock case with recognized factory ratios are
allowed with no weight penalty. (Must have documentation for ratios and are
subject to scrutiny). Gearboxes such as Jerico, G-Force, Saenz, Hewland, &
Quaife etc. will be penalized 75 LBS, ratios are free. Reverse must be fully
functioning in either case.
2.3
Datsun allowed alternate transmissions with no weight penalty:
All Z car, 200SX or Truck (Stock/Syncro) 4 or 5 speed overdrive transmissions.
Nissan Competition Direct Drive Transmissions:
32010-N3220, option 1- 1st 2.818, 2nd 1.973, 3rd 1.470, 4th 1.192, 5th 1.00
32010-N3221, option 2- 1st 2.348, 2nd 1.601, 3rd 1.296, 4th 1.138, 5th 1.00
32010-N3222, option 3- 1st 2.192, 2nd 1.601, 3rd 1.470, 4th 1.138, 5th 1.00
32010-N3201, option 4- 1st 3.321, 2nd 2.270, 3rd 1.601, 4th 1.240, 5th 1.00
Optional Nissan Competition 1st gears (1.813, 1.832, 1.858 and 1.97) are
allowed on any Factory transmission.
Optional Nissan Competition Webster Input Reduction Gear allowed on any
United Kingdom Elite Transmission Gear sets in a Nissan A or B case
Nissan Competition early “A” Transmission with 3 piece case:
Option 1 – 1st 2.678, 2nd 1.704, 3rd 1.262, 4th 1.00, 5th .852
Option 2 – 1st 1.858, 2nd 1.388, 3rd 1.217, 4th 1.00, 5th .852
Option 3 – 1st 2.554, 2nd 1.758, 3rd 1.271, 4th 1.00, 5th .852
Nissan original equipment (standard)
1st 2.957, 2nd 1.858, 3rd 1.311, 4th 1.00, 5th .852
Where are you located??
I've had & sold two of these Option boxes over the years. Les Canaday bought one of them. went in a BS resto build. Rumor has it, he also acquired the majority of the Datsun/Nissan Comp Option box PARTS from Nissan, when they moved to Tennessee......?? That said, it is a VERY expensive way to go, but if it is what you want, it is what you want!
As mentioned above, Elite Gearbox in the UK offers a reproduction gear set. We have tried to use two sets, both had inherent issues, that Elite does NOT acknowledge. We struggled with both & finally gave up. Troy Ermish is the USA distributor for Elite. He has figured out WHAT the inherent problem is & makes the corrections/modifications when he builds a trans. You would have to ask him if he would sell a modified set, but I think he wants the full job, so he can manage it himself (because of the problems etc). Again, Elite does NOT acknowledge the problem.......BEWARE!
We ran rebuilt STOCK 77-83 280Z/280ZX 5speeds up thru approximately 250hp in our 240Z's. Once we developed more hp, we were wearing them out/breaking them, so we tried Elite, then moved on to something else. Rebuild kits are available, but gears, hubs & shift forks are NLA NLS, so getting hard to find. Otherwise, the stock gearboxes are pretty stout!
Sam Neave in N Carolina (??) builds a proprietary gearbox, based on a production 5spd, mixing & machining some of the gears to suit. I believe Steve Bonk out of Chicago runs his gearboxes............??
I have a STOCK Roadster 2.0L 5spd if interested. It WAS fully/freshly rebuilt, but the numbnutz left it outside, so it got some water in it. The lower gears are oxidized, but we think they would clean up nice with some light GLASSBEAD work (NOT aluminum oxide etc!). PM me if interested!
TJ
TJ
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
Located in Califonia, the Bay Area (central to northern California)... if you have contact information for any of the folks you mentioned (like Les) who picked up the Nissan parts and boxes, message me... would love to reach out to them. I am still in the midst of a 9-10 month process. Just found the carburetors I was looking for... last remaining challenge after the option 2 box is the paint scheme. Already decided its a non-BRE theme...
This is a shitty gear set for anything but racing. Taking off in first in the competition box will be like taking off in second gear in most stock boxes.
Are you building or perhaps Troy Ermish is building for you? He just posted today of a new BS build, where the owner is looking for ideas for a paint scheme!UndecidedRacer wrote: ↑20 Dec 2021 09:39Located in Califonia, the Bay Area (central to northern California)... if you have contact information for any of the folks you mentioned (like Les) who picked up the Nissan parts and boxes, message me... would love to reach out to them. I am still in the midst of a 9-10 month process. Just found the carburetors I was looking for... last remaining challenge after the option 2 box is the paint scheme. Already decided its a non-BRE theme...
Les Cannaday is Classic Datsun in Vista, California 92083 760-940-6365 les@classicdatsun.com. He apparently acquired a large portion of the Datsun Comp parts......?? Be prepared $$$$$$$$$$$
What carbs did you find? My ex BS car has a very early production intake that does not have branding, with Dellorto carbs & a hand made hard rod accelerator linkage up from the bottom............near the header! Original owner/builder said he bought parts from BRE, but Pete Brock said "Carb set is not mine!" I'm hoping the car goes BACK to the original owner, as he says he wants it!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
