Trunk Lift gas supports?
anyone done gas struts for trunklid? missing the trunk torsion bars so instead of hunting for some wouldnt mind rear gas struts like hood has
Mike Gibson
Re: Trunk Lift gas supports?
Too bad we are not a bit closer. I have a couple extra sets of them hanging in my garage. I have one set from a '69 model that I will be using on my car, and a couple sets from 71 or 72 models. The early cars had a straight torsion rod, while they put a couple of bends in the later models to go around that little vapor tank that mounts under the rear shelf.
Seems like an arrangement similar to a 350Z rear hatch would work for the trunk. I've never seen it done before though.
- Guy
- Guy
See what's happening in Arizona... WWW.Desertdatsuns.net
they arent heavy so not that bad to ship to wa-- lemme see what i can find --
Mike Gibson
Hey Mike, did you ever work out a solution for the trunk gas lifts? I am realizing the location of my fuel cell will interfere with the hinge tension rods. May do some experiments with this. I am assuming some variant of the hood gas lift solution would work. Anyone have a solution, let me know. Thanks.
- eastbaysolo_73
I would be interested to know as well what would work. Following .72ultraorange wrote: ↑24 May 2022 04:29Hey Mike, did you ever work out a solution for the trunk gas lifts? I am realizing the location of my fuel cell will interfere with the hinge tension rods. May do some experiments with this. I am assuming some variant of the hood gas lift solution would work. Anyone have a solution, let me know. Thanks.
My build thread
My build thread
I got some original supports from Guy and put them in. works great.
if u do it let me know. the green one has a bonded rear spoiler and the oem springs barely hold it up
Mike Gibson
