Hey fellas,
Found these in my storage. Can some one please identify what they are and where they're mounted?I have a hunch but not sure. Are these related to seat belts? If anyone can share a photo of there location that would be great ? Im going to restore them and install them once I know where they go. Thanks in advance..
image0 2 by v p, on Flickr
What are these?
- eastbaysolo_73
What are these?
My build thread
My build thread
Re: What are these?
I suspect your hunch is correct.
- eastbaysolo_73
Re: What are these?
Awesome ! Thanks WxMan very much appreciated. Now I have to find some screws after I clean them up.
My build thread
My build thread
Re: What are these?
OMG are you using stock seatbelts
Mike Gibson
Re: What are these?
That's not a picture of stock belts.
Re: What are these?
It's a Datsport belt.
- eastbaysolo_73
Re: What are these?
Im not most likely Datsport belts.
My build thread
My build thread
Re: What are these?
I will likely have the correct chrome tapered head screws if you need.
See how that aftermarket belt has a plastic "sheath" that hangs down much lower than the OEM seatbelt (they did not have a sheath)? That sheath likely won't fit into the OEM clip, so get your seat belt kit BEFORE you install those clips, unless you simply want the factory look of that clip.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
- eastbaysolo_73
Re: What are these?
Will do. I haven't installed them yet.yenpit wrote: ↑08 Jul 2021 13:15 I will likely have the correct chrome tapered head screws if you need.
My build thread
My build thread
