Sup fellas,
Does any know the size screw that holds the upper door card bracket in place?
Door card bracket question
- eastbaysolo_73
My build thread
My build thread
Re: Door card bracket question
I will have correct OEM. I can try to grab
If you go buy, get phillips head, tapered head, FLAT head...............not a domed head. They need to sit flush with the rail, otherwise your door panel/card might not slip in!
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
- eastbaysolo_73
Sorry for the late reply Yenpit. If you have the OEM ones i'll take it. I need a set for the two front doors and rear cards as well.
My build thread
My build thread
PM sent!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
