2door all apart
Re: 2door all apart
That rotisserie is nice. Jealous of people who have them. I’ve got to replace the entire rear of my car so a rotisserie is not in the cards. Have fun upgrading the shop. Looks like you have some good space to work in.
Stu
1972 4-door 510
2004 Volvo V70R 6spd manual
Factory Five Racing Cobra
1972 4-door 510
Re: 2door all apart
Thanks just need time cause I work 100 miles south of my place during the week. I'll get there slowly for sure. Good luck on yours.
Re: 2door all apart
Been busy but the mason fella came by and did most of what was left on the pointing on the brickwork so now to clean things up and get back moving on the car.
Re: 2door all apart
Got to get everything moved away from the car on the rotisserie to get back on it but am getting the L20b ready to be assembled that will be going in it.
- 12BB27D3-9FFD-41BE-B8BC-F36514CF8B1E.jpeg (617.21 KiB) Viewed 1489 times
Re: 2door all apart
Well got the crank in the motor, and getting the pistons ready to go in now. Next gotta clean up around the car on the rotisserie.
- 4833CA6B-639F-4EBF-8729-406E3A2963C3.jpeg (167.37 KiB) Viewed 1367 times
- 99EE3CAF-0E8A-43F4-A8F9-17FC8D586D84.jpeg (183.73 KiB) Viewed 1367 times
- 5DEEFD32-BBCE-49B2-AF99-A14FEB135218.jpeg (696.21 KiB) Viewed 1367 times
Re: 2door all apart
Had to get the piston rods or wrist pins to loosen up over the years I had sprayed Marvel Mystery Oil on them to keep them from any rust developing. Two where very tight or stiff so I sprayed some Marvel Mystery Oil on them all over a few weekends and they loosened up fine the old oil I sprayed on them had dried or jelled up and now they are smooth as silk. Next to put the rings on them and install.
- C848D3C8-6CDD-4E53-A8F2-20F75E5DA9A0.jpeg (696.21 KiB) Viewed 1221 times
- 0FB9FD2C-EE8D-4230-885B-361F5A90D070.jpeg (558.77 KiB) Viewed 1221 times
- 0E87BC21-A4D8-49EA-ABC0-98366216A2AE.jpeg (561.02 KiB) Viewed 1221 times
Re: 2door all apart
Pistons install in the L20b.
- Compress_20230707_181227_7888.jpg (486.92 KiB) Viewed 1073 times
- Compress_20230707_181226_6160.jpg (476.98 KiB) Viewed 1073 times
Re: 2door all apart
Found the front cover for the L20B and probably most if not all the bolts to the front cover, the chain guide's, oil pan. Still more to locate. Got to figure just clean the cover up or get it shined all up. Found the new chain guide's and tensioner, timing chain with cam and crank sprocket's and oil pump as well as the gear thing that runs the oil pump and distributor. Now if I can just win the Powerball tonight I'll go buy those two two-door Sedans for sale south of here in Mandeville and Ocean Springs.
- Compress_20230710_175003_3405.jpg (482.86 KiB) Viewed 1040 times
- Compress_20230710_175002_2008.jpg (462.61 KiB) Viewed 1040 times
- Compress_20230710_175000_0351.jpg (484.23 KiB) Viewed 1040 times
- Compress_20230710_174958_8972.jpg (471.58 KiB) Viewed 1040 times
Re: 2door all apart
Thanks I'm slowly trying to get there, I retire next year so I'll have a lot more time to get things done.
Re: 2door all apart
Got 3 half moon keyways to get back on the L20B.
- Compress_20231106_073642_2509.jpg (474.64 KiB) Viewed 1007 times
Re: 2door all apart
Off this week so trying to get back on the motor. Got to get all the parts for the head rounded up and sorted out.
Re: 2door all apart
Got some new rocker arms coming for the head. And cleaned up some around the car so I can get some things going again. Still gotta get a lot of what I moved away sorted out and regain some room on the other side of the garage. Now that I'm retired I hope to regain control of my building and get rid of a lot of trash little by little.
- Compress_20240713_100232_2810.jpg (694.66 KiB) Viewed 259 times
- Compress_20240713_100450_0992.jpg (476.99 KiB) Viewed 259 times
Re: 2door all apart
Been looking for these top hats for a while. Then remembered I had a bunch of parts I had put somewhere. When to the next room over by the scaffolding and wala. Now to figure out how all of the front coil overs go together with the strut and camber plates. I believe I can remember most of it. I had bought it all way back trying to do it on the cheap. I also have the old school setup I originally intended to use on the Goon but I have the 300z rims on her so they don't go to waste. So I figured I'll have to go with the newer style coil overs cause of the rims and tires on the Goon. I'll just have to figure what I'll need when the 2 door Sedan gets ready in the future at that time. Also used an old decal sticker I wasn't sure would work but it looks like it did. All in all I plan to lower the Goon soon.
- Compress_20240726_112420_0046.jpg (162.77 KiB) Viewed 190 times
- Compress_20240726_112420_0992.jpg (240.88 KiB) Viewed 190 times
- Compress_20240726_112421_1285.jpg (414.02 KiB) Viewed 190 times
- Compress_20240726_112420_0580.jpg (248.46 KiB) Viewed 190 times
- Compress_20240726_112420_0776.jpg (256.51 KiB) Viewed 190 times
