Black and Blue '68s
- two_68_510s
Re: Black and Blue '68s
Well I am preparing to do the final bagging and resin infusion of my primary plenum section. It had been molded in a fiberglass mold with a custom bladder inside. In the Process the bladder folded slightly inside the mold and created some voids. So I have used another two layers of carbon to cover the part. I filled the inside with 6 lb foam to hold the shape against the pressure of the vacuum bagging. The foam takes place of the bladder which broke up during the process. I will try to remember to takes pics, which I didn't do on the last molding.
Acetone will melt the foam completely when epoxy sets up, it doesn't touch the epoxy.Joel
Neat stuff Joel
Pretty trailblazing stuff there Joel. Good to see you back at it!
- two_68_510s
Well, I am back home like everyone else, and have time for the 510! Thought I would complete the dash before assembling the engine. No connection really, just know more about wood than engines!! Inside of glove box door, Carpathian Elm. Vacuum press
- two_68_510s
- instruments.jpg (194.84 KiB) Viewed 2083 times
- 92665418_2833785986740784_5900022425923354624_o.jpg (188.5 KiB) Viewed 2090 times
Beautiful work!
- two_68_510s
Thanks! better next week when finish is on completely
