Ecology 510
Ecology 510
Bare with me i'm still a newbie. so i bought a 1970 510 4door from a local Ecology junkyard on 9/25/10, and I'm doing a 22r temporary swap to go to school till i raise up money for an sr20 or ka24 or maybe a rotary.
- 181959_129309757140319_100001838878001_200163_2149601_n.jpg (66.27 KiB) Viewed 3906 times
- 181753_129309550473673_100001838878001_200162_8341362_n.jpg (81.68 KiB) Viewed 3906 times
- 181724_129309060473722_100001838878001_200161_6084576_n.jpg (70.2 KiB) Viewed 3906 times
Re: Ecology 510
the car has a bit of rust on the fenders but that pretty much it.
- 184292_129309903806971_100001838878001_200164_4970992_n.jpg (69.49 KiB) Viewed 3903 times
- 206564_138017079602920_100001838878001_249675_4141536_n.jpg (93.67 KiB) Viewed 3903 times
- two_68_510s
Re: Ecology 510
Why not make it easy on yourself and put an old L-series in there?
Re: Ecology 510
This is what it looks today. painted suspension,new ball joints, and some 15x7 0 offset wheels.
- b510.jpg (80.02 KiB) Viewed 3899 times
- a510.jpg (80.57 KiB) Viewed 3899 times
Re: Ecology 510
it still have the l16 with an automatic trans if i want to put it back in but i needed an engine so i can go to college.
Re: Ecology 510
If the L16 and auto work - why not use them? Pretty simple and bulletproof (generally).
Re: Ecology 510
Hope you don't want to lower it much.SANDMAN3622 wrote:and some 15x7 0 offset wheels.
I'm with the "stick the L-series back in" crowd. Since you have time to swap a 22R in, why not just stick the L16 in and spend your time sourcing a 5-speed and the manual-trans swap parts?
Re: Ecology 510
May I have your old hubcaps?
Re: Ecology 510
Asside from maybe the price of the motor set ....... I don't see how a 22R swap would be easier/cheaper/quicker than a KA24DE swap
it's worth $1500 rigt now without wheels ..... .. $1,300 with a driving 22R ....... $2,500 with a running L16 ...... $5k+ with a KA24DE
Those wheels will fit fine with stock rear camber,,, and 280zx front struts
Re: Ecology 510
How much camber is stock in the rear on a 510, anyway? Sure, they'll fit once you lower it if you don't correct the camber after lowering, but it's the same fitment issue the Konig's had/have. And it would seem silly to correct the rear toe out after lowering but leave the 5° of negative camber. You're going to need as much tire on the ground as possible once he goes KA.indy510 wrote:Those wheels will fit fine with stock rear camber,,, and 280zx front struts
Re: Ecology 510
The L16 was trashed really bad when i found the car at the junkyard but i have everything to put it back in. i wanna keep the 22r for now and then i'll rebuild the engine and look for that 5speed trans. also i have a 620 datsun truck if you can see it there in the picture background with an L18 with a 4speed, i can put that in.
what kind of car am i look at for a 5speed??
Re: Ecology 510
Depends on which one (gearing, length, fitment) you want.
DQ Volume 11 Issue 4 - Tech How-To: Nissan Transmission Identification — Taking the guesswork out of identifying Nissan transmissions, Mike Rogers lays them all out, providing the original applications, gear ratios, and key identifying marks. Dont know your FS5W63 from your FS5W63A? This article will clear up your questions.
Re: Ecology 510
280zx transmission sounds good to me. for the L16 or for the L18 i got.
but swapping a ka would be AWESOME!!!
Re: Ecology 510
L16 might not like the ZX 5th gear.
Re: Ecology 510
Well it's worth a try. but do you mean that the L16 can't handle the 5th gear?
