Hey my friend has a 510 and Is getting a l20b rebuilt, he wants to run duel 45 webers but he also has a break booster. I'm pretty sure the brake booster would be in the way for the rear carburetor. Just wanted to know if anyone has an idea.
Thanks
How can you fit duel 45 webers on a 510 with a brake booster?
- PMCS Rally
Re: How can you fit duel 45 webers on a 510 with a brake booster?
This is the only way I know.....
- 510 engine bay.PNG (462.38 KiB) Viewed 1645 times
Hairpin-Circus......
We Do It In Corners
We Do It In Corners
I believe it was Cannon that made a high rise dual side draft manifold for the 620 that places the carbs above the brake master cylinder. It may be a bit difficult to find one, but it could be a solution to your problem. This thread has a picture of said manifold as an example: https://ratsun.net/topic/77500-side-dra ... t-options/
I’m running an L20B with B210 brake booster / 280ZX brake master and DCOE45s. I can’t recall the manifold brand but I think it is the short 2 piece unit from Pierce Manifolds.
I think this might be the manifold set: https://www.piercemanifolds.com/product_p/mt-0037-c.htm
