Help needed identifying struts
Wilse
Post by Wilse »
Hi all. Would any be able to help me identify these struts/ brakes. Thought they may be 280 ZX but calliper looks different to my other set..
Re: Help needed identifying struts
Post by datzenmike »
Springs are too small a diameter for zx too. Rotors look extra wide to me.
Tedman
Post by Tedman »
Google search comes up with these calipers for a Holden XB:
https://www.vintage-mustang.com/attachm ... pg.277433/
Maybe someone could ID the struts from the part numbers stamped into the strut tube?
I might be able to if they were even used in N America. Ten digits starting with 54302-????? for RH and 54303-????? for LH
Girlock.... I wonder if related to Girling Brakes bought out by Lucas (prince of darkness) in 1938.
Wilse
Post by Wilse »
The only stamping at the moment that I can find is 8X28. Fairly large stamps used. Nothing identifying the brake pad. The rotor measures 24 mm across. Dr Google was no help to me..
Wilse
Post by Wilse »
And one more of the rear of caliper..
Probably not Nissan.
