I have a 68 510 L-16 motor with it's pressure plate + clutch
I swapped a dogleg 5 speed in there using the dogleg tranny bearing and collar, and I was getting this nasty sound like something was rubbing or scratching, my dad thought it was the trowout bearing, could have been.
What bearing or collar do I use in this swap?
What bearing and collar do I use
68 4doorFanatic
- SteveEdmonton
Re: What bearing and collar do I use
The standard answer to this is, use whatever bearing and collar matches the clutch. It doesn't matter what transmission-- or motor-- you're putting all of this together with, it's the clutch that's the key. So if you're using the clutch from your L16, you should use that same TO bearing and collar. And hopefully that should scratch your scratch!
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Thanks! finally i get an answer and a straight forward one!SteveEdmonton wrote:The standard answer to this is, use whatever bearing and collar matches the clutch. It doesn't matter what transmission-- or motor-- you're putting all of this together with, it's the clutch that's the key. So if you're using the clutch from your L16, you should use that same TO bearing and collar. And hopefully that should scratch your scratch!
68 4doorFanatic
Can't go wrong with the bearing (always replace) and bearing collar that was matched to your L16 clutch. The dogleg was also used with a 200mm clutch on the S10 and A10 and it should work. The bearing is likely bad and should ALWAYS be replaced.
Compare the two bearing collars for length. I'm curious how close they are.
