Rare Hayashi Racing Super Street JDM Centerlock Wheels with Toyo Proxies R888
Sp3
Post by Sp3 »
Hayashi Racing produced these wheels with similar visual queues to those used in motorsport around the world including but not limited to Can-Am, Formula 2 and Formula 1. A popular design, a classic 5 spoke with inset step shared and tweaked by many manufacturers.
Long out of production was only offered in limited numbers.
The super street center lock system is awesome.
A adaptor bolts onto you hub similar to a spacer and allows you to run these hayashi racing centerlock rims.
Once the steel adpator is bolted on, slide your rim on the thread on the single alloy nut tighten using the centerlock tool (massive socket) with its breaker bar or use a massive torque wrench and away you go! Simple.
On offer:
Complete set of Refinished Hayashi Center Lock wheels, hub adaptors, center caps, and locking wrench. Mounted on Toyo Proxies R888 with 66% treadlife. Ran 3 years with no issues. Anti-seize always used on center cap threads. Wheel is rare and no longer in production. Can provide additional photos as requested.
Manufactured May1981
Bolt circle 4x114.3
Offset is +2
wheels are14x7
Toyo Proxies are 205/55/14
$2900 obo
https://www.dropbox.com/sh/jnm7fw189vo8 ... hfi7a?dl=0
Re: Rare Hayashi Racing Super Streets JDM Centerlock Wheels with Toyo Proxies R888
Post by 510rob »
For $2900, people might want to know the size and spacing of the rims...
Sp3
Post by Sp3 »
Thanks for adding oldsklgarage.
Yes, based on stampings inside wheel, here are the following specifics:
Manufactured May 1981
Bolt circle 114.3
Offset is +2
wheels are 14x7
